What adhesive for 40kg m2 natural stone
Raydaffurn
im looking to install natural stone onto hardie backer board it's in a living room wall.
The tiles are heavy, about 40kg m2 which adhesive do I need?
Not sure if I need quick or slow set, flexible or not etc... if someone can recommend
I think the title is a bit wrong, what stone is it and a fast set would be my choice
Cumulative weight will be high so i think hb is a good choice of substrate. Adhesive-wise, i would use whatever you like and trust. It's not a particularly sensitive stone but always safer to use a rapid set.
Personally I'd use tilemaster semi-rapid.
Hi as the stone is relatively light in colour we'd recommend Keraquick White adhesive. For further info you can visit products - http://www.mapei.com/GB-EN/Products-for-Ceramics-and-Stone-Materials/Cement-based-adhesives/KERAQUICK-S1 or call our Technical Services Team directly on 0121 508 6970 (ext 2) for advice. Hope that helps. 🙂
I think it depends how capable the man is with laying tiles , or these interlocking mosaic.
Id use white slow set or as impish says semi rapid (tilemaster would be my choice)
Tilemaster standard set white . It's made for the job. Trust me 42 years experience and tile master is the way forward
Raydaffurn,
Paul Bleasdale,
Raydaffurn,
Paul Bleasdale,
