What acrylic primer?
antdad
Happy new year gents.
I'll soon be fixing very large tiles on water resistant plasterboard, is the Mapei acrylic primer from Screwfix okay or what would you recommend?
Regards
What adhesive do you recommend for a large wall tile (90 x 30cm) seems the Mapei ady I was thinking of using isn't suitable.
Mapei Keraflex C2TE / Keraflex Maxi s1, needs no for plasterboard primer.
plasterboard course, not the skimmed.
I am sure, because I contacted Mapei 10 years ago, for 7 marble bathrooms, bathrooms are still in place.
Then, a primer coat does not hurt.
Now do not scold 😉
90x30 mapei keraflex maxi s1 for me.
I've never known a situation where priming is detrimental to the work even if not specified as a necessity
I'm pretty sure bal don't recommend using primer on ply (the tiled surface) when using bal single part fast flex...
They might not specify it as required but I bet if you asked them if it was OK to do they would say you can if you want .
antdad,
antdad,
antdad,
antdad,
