Wall panels in shower room
Deleted member 19391
I am building an extension which has a ground floor shower room. So I looked at differerent types of panels and reckon that the Bushboard Nuance are what I want. The shower is 1200x800 with a window in the 1200 end and going to panel the toilet and basin wall, so five in total. These panels are expensive at £215 each, is the best price I have found from a local plumber merchants.
For the colour matched sealant how do you calculate the number of tubes required as they are pricey as well.
Tried IDS in Swindon and they are more expensive and other places are more as well.
Any tips for getting a better price?
Once you’ve chosen which sealant you require, search out its pdf, and it’ll give you consumption per linear metre.
Upvote 0
Don’t they say one tube of adhesive per board? There Silicon I wouldn’t of thought you would need more than a couple of tubes, the joints, corners and around the shower tray.
John
Upvote 0
😉Ok so confusion setting in John. 🙂
You’re mentioning adhesive and sealant and tube all in one sentence here.
Can you clarify for me please.
You were asking about consumption of colour matched Silicon to seal the transitions weren’t you?
Where did adhesive come from? Haha
Typically, two tubes of colour matched Silicon would do the whole room and possiblygive them a spare tube for future issues.
If your on about sticking these wall panels, I’ve only done a couple, and we used CT1 it’s not something I’ve dealt with in any depth.
Upvote 0
I’m sure Bushboard supply there own adhesive to stick the boards to the wall. I think they say one tube of adhesive per board. If you use CT1 and anything goes wrong I’m bet they would say you should of used there adhesive.
There colour matched Silicon is only for sealing around all the edges and for the tongue and groove joints. So I would say a couple of tubes.
John..
Upvote 0
Spot on @Jonathanb ^^
Bushboard are known for being meticulous in checking any claims and refusing to payout if any other products are used. Having said that it is by far the best board on the market and doesn't need its own products to work well unlike others.
Upvote 0
Thanks you for your responses.
Bushboard suggest using colourless adhesive to fix the boards to the walls and a colour matched sealant to seal the visible joints. They take the view that if you buy the sealant in the same order as the boards then the warranty is valid.
Upvote 0
Personally I would just use what they recommend. I’ve just helped my dad do one, I can’t recall the brand but the colour matched stuff for sealing the corner etc wasn’t Silicon it was much superior.
Edit, is is bushboard I did
Upvote 0
Best Bathroom Tiles
Unsolved
Deleted member 19391,
Brian Hall,
Brian Hall,
