Uncoupling membrane vs no more ply, when & where?
I didn't use the word difficult . Tricky , bouncing timber floors . Floating floors , walls with hanging plaster . Pretty much much anything that I have to put work into to bring it up to a standard that I will be happy to tile on without it failing I regard the biggest enemy of a tiler is a moving substrate .
I always use 6mm Hardie to over-board a timber floor, glued & screwed. I would only use an uncoupling membrane if I was fixing stone or on to a newish screed. Keraquick on every floor.
What primer you use (if any) on timber/chipoard floor before putting hardie down ?
Can i just point out that tilemaster mat and BAL rapid mat are not single layer construction. Both offer far more than single materials such as mapeitex etc.
Scott HAZARD,
One Day,
Scott HAZARD,
One Day,
