Discuss Two separate shower traps? in the Tanking and Wetrooms area at TilersForums.com.
Ajax123
1,213
Lincolnshire
The traps ability to get rid if waste is not just down to pipe size. It also depends on the trap entry not becoming air locked. I found this when I installed my own shower. I put a standard floor waste in with a 50mm pipe outlet yo a shallow p trap. It kept bunging up because the shower out water ok top faster than the it could get into the trap entry thus air locking and overflowing. I ended up changing the trap to one called a fast glow trap which as the water enters the trap it creates like a vortex stopping any air lock. Now works a treat.my shower is rated at 40litres a minute when on the pump...
Q
Qwerty
As Alan says above, a fast flowing trap is all that is required. Are you running a combination boiler or conventional tank & cylinder?
Cranbrook
598
Pontypridd, South Wales
Its an unvented system (two boilers in a low loss header system. I don't think a fast flowing trap will be sufficient given the flow rate, so I think I'm gonna screed in two separate drains and run separate 40mm waste
Reply to Two separate shower traps? in the Tanking and Wetrooms area at TilersForums.com
