Tilux shower and wet room former site...wetdecs
wetdec
The Tilux Shower Tray Former For Wet Rooms And Level Access Showers.
The all-in-one wet room shower tray former and gulley system for level access wetroom showers
TheTilux is manufactured specifically for wet rooms. The Tilux wetroom former is the most advanced shower tray and gulley system available for wet rooms in the UK. Ideal for new and refurbishment projects where floors are made of concrete or raised. Manufactured in Germany the Tilux tray has been constructed with the installer in mind :
  • Totally waterproof, offering complete peace of mind.
  • Gulley collar factory fitted - gulley locks and seals itself into place.
  • Rigid EPS construction far stronger than the grey insulation type boards.
  • Overal instal height of 115mm maximum.
  • Pre fixed waterproof membrane sealed into gulley collar.
  • Can be cut to shape
  • Horizontal or vertical waste with knuckle adjustment.
  • Works hand in hand with the Dura-wp tanking kits
  • Tanking membrane overlaps tray to seal to surround.
Made of extremely strong rigid eps, unlike the Tuff2, Aquadec or any other former at the moment the Tilux tray has a factory molded and bolted flange which the tanking membrane is fixed to and the wet room gulley locks into with rubber seals so no putty, paste or Silicon required. The gulley revolves 360 and a knuckle joint helps align pipe work this system is very secure and DIY friendly.
To add to the ease of installation the shower tray former has a waterproof tanking membrane fixed to its upper surface. This membrane overhangs by approx 3" so it can be sealed to its surrounds. The tilux wetroom solution can be used with most leading tanking systems although theDura-wp membrane is recommended for ease and value.
This former is a breeze for installers as it covers all the bases making the fix quick and worry free. The Drain flange takes away the stress associated with making secure waterproof joints and the tanking membrane is already fitted to the base.
All fittings come in two boxes the only addition will be your choice of tanking kit and a screen if your thinking of using one.
Web Site ……………… www.tilux.co.uk
Tilux Install video…………....Here
Tilux.pdf………………..Here
Tanking | kits
Dura-wp.pdf……………Here
Dura-wp tanking install video...............Here
Tiling Wood Floors | UFH
Dura-ci .pdf...............uncoupling | tanking membrane
As always any questions [email protected] are here to help :thumbsup::thumbsup:
Tiler
Thanks for this Wetdec.
I'll be in contact next week to place my order.
I'll also let you all know how I get on. As it's the first wetroom installation I will have done it'll be a baptism of fire for both me and the Tilux!
Tony, it only mentions screed floors, can this be used on suspended floors too?
Ther's always 1 isn there LOL
Ok me personally I would install the Tilux on concrete, wood and suspended floors and not bat an eyelid, trying to get Germany to qualify this is like chewing leather.................
If my word is good enough then yes on standard joists applying general practice and without underboarding............:thumbsup:
If someone wanted it drawn up for a particular situation then I would oblige.........
tiler
As a first time installer I can recommend this product as being suitable for concrete screeded floors. I've just put one down yesterday using flexible spf, and it set solid.
It's almost as hard as the screed!
When tiling accross to the rest of the floor does this need an expansion joint at the join, or does the fast flex cope with this issue?
I am just looking at doing my first wet-room, what adhesives do you advise? also where is a good supplier as I am in derby?
Thank you for all the great info :thumbsup:
wetdec,
wetdec,
wetdec,
wetdec,
