Discuss Tiling Outside - Advice Please in the UK Tiling Forum area at TilersForums.com.
Tilestiles
Hi Everyone. Been a while since I posted on here as not been too good so have had to lay off the tiling for awhile. Howevre, I have just got a job tiling the entrance to a local club. Entrance floor needs doing (Approx 4m2 plus the entrance walls again 4m2). Both walls and floors will be open to the elements so my first question is do I need to use any special adhesive or do the tiles need to be of a particular type?? My second question is that the entrance walls are currently brick, so can I tile directly onto the brickwork? Any advice would be very much appreciated.
G
GazTech
Rapid set external is fine for both jobs, be sure to scrape any loose bits from the brick, and a coat of primer wouldn't be a bad thing. Regards the tiles if exposed to frost, make sure the are the correct grade, porcelain or Quarry tiles are the best....Gaz
Reply to Tiling Outside - Advice Please in the UK Tiling Forum area at TilersForums.com
  • Question
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
