R
Rob Z
Hello Ms Cabbage, to add to what has already been said...maybe you are mixing your thinset too stiff...mix it a bit looser and you will see that you can get the micro-adjustment that you need to align the tiles. Travertine is porous and will start immediately sucking the moisture from the thinset.
As the other guys said, if your surface is flat and the tiles are flat, you just need to modify your technique with the setting material. Like Dave, I would probably use a 1/2" notch trowel (12 mm).
