jus001
Did u see the sink?
Made from 4.8mm porcelain.
Why do u need to polish the underside?
Yep, sink looked good!
I was planning on using left over tiles from the walls and floor or possibly a thicker 20mm tile to create the walls but doing that one side would be unfinished. I guess I could use two 12mm tiles back to back however and that would solve that problem. In fact that would probably be better as the corners could overlap which would make it easier to stick together and perhaps a bit more robust afterwards.
Do you have any suggestions as to how to create the run off towards the drain? Initial thoughts were that I could create the surface in two parts, one larger slightly sloped section that would direct the water to a smaller flat section at the back with the drain in.
My tiling experience is limited to the splashback behind my kitchen sink so simple is good - also I don't want to spend much money in case it looks awful afterwards 🙂
