N
newplumb
Hi there. I'd appreciate some advice please....
My first time tiling with travertine. The customer is going for 600x400 (12mm thick) tiles. The plasterboard around the shower-bath is to be replaced by aquapanel, so can I just check whether you would recommend that I carry out any surface preparation to the aquapanel before tiling with these tiles.
Around the rest of the bathroom, the tiles are only going to go up to a height of approx 1200mm (i.e. 3 tiles high). The walls are a mix of plasterboard, and solid (brick and plaster). I would also appreciate some advice on the best approach to preparing these walls (I'm guessing Im going to need to replace the plasterboard!).
Finally, if you could recommend the most suitable adhesive for the above mix of surfaces I'd be most grateful.
Thanks in advance
Matt
Thanks in advance
Matt
