patl
There's just too much info here. The more I read, the more confused I get, so please be gentle :smilewinkgrin:
I'm ripping out our existing bathroom that's 3mx3m. The current chipboard floor isn't all in great shape, and most of it is water damaged or covered in old tiles so would just require extra work to remove the old cement etc.
My current plan is to remove the lot, pack the joists where necessary to get it as level as possible and put an 18mm wbp subfloor down in its place. I was planning on covering this with 6mm ekoboard or similar, then ufh, then slc. Depending on how flat it ends up I'll see whether I feel confident of putting the 300x600 tiles down or whether I get a tiler in.
Now I'm starting to think that instead, maybe I should go for 22mm wbp, sacrifice the insulation board and go with durabase-wp or similar. I also wonder whether an extra 4mill of ply really makes any difference in a 9m2 room as long as the ply is securely screwed at 300mm centres.
As the chipboard+tiles are only around 20mm currently, I'd rather not add any more height than necessary, so any help would be appreciated.
Thanks,
Pat.
Thanks,
Pat.
