Currently reading:
Sigma Not Measuring Correctly
Discuss Sigma Not Measuring Correctly in the Tiling Tools area at TilersForums.com.
Q
Qwerty
Hard to word the title really, but essentially here is the issue....
The measuring bar on my new sigma is 'off centre'.....see photos...
Basically if I put a 400mm tile on the cutter with 200mm to the left of 0 and 200mm to the right, when I score & snap, the left piece is 199mm whilst the right piece is 201mm. You get the idea.....
Question is can this be sorted or do I send it back? I flipped the bar when off of the cutter and noticed 3 Philips head screws which appears to hold the bar to the fixing plate that has the lever on to clamp it to the cutter however the whole thing appears glued together with clear glue?
Ideas please people!!!
I forgot to take photos of the underneath but will do so tomorrow
Reply to Sigma Not Measuring Correctly in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
