Discuss Rubi 66 max problem new cutter new tiler in the Tile Cutters area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
A
Andrew Smith
Hi all, relatively new to tiling but I’m giving it a good go!
I’m having major probs with my (new ish) rubi 66 max
Every time I cut a tile down it’s length the left hand cut smashes a corner off - doesn’t matter what the thickness of ceramic tile?
Isn’t to bad when cutting along the width but it’s a heart in mouth thing every cut !!
Please see pics
Am I doing something wrong or is this a common fault
Thanks - Andy
G
GoneGuy
Are you making sure your scoring all the way to the end with equal pressure? Try changing the scoring wheel
Albert
View attachment 99956 View attachment 99957 View attachment 99958 Hi all, relatively new to tiling but I’m giving it a good go!
Please see pics
Thanks - Andy
Try just squeezing the breaker, don't jerk it and after you score
the tile move it back towards you slightly.
Spare Tool
The breakers are a crap design...good for nothing except metros imho, and yes ive got one and metros are the only time it see's the light of day
Chris N
You might find the snapper is slightly bent...was on mine, so fitted an upgraded breaker from Tradetiler...been fine since.
You have to be confident when smapping the tile. You need a good firm and smooth motion.
GAZ5518
Try turning tile around and snapping other end.. Also score and break over your knee...
(Rubi user for a number of years now)!:eek:
Albert
Please see pics
Thanks - Andy
If you are still having problems the tiles you are cutting are just ceramic so you should be able to snap them with your fingers.
Andy Allen
I know exactly what to do.
seen this problem many times.
You need to pick up you cutter.
Take it outside.
Find the closest bin.
And through it in.
Go back inside.
Go on tinternet.
And purchase a Sigma.
This should solve the problem.
A
Andrew Smith
Take it outside.
And through it in.
Go back inside.
Go on tinternet.
Cheers mate - and I hear what you’re saying but that cutter cost over £200 and came recommended- I’ve always thought it was the breaker so I’ll replace that
Reply to Rubi 66 max problem new cutter new tiler in the Tile Cutters area at TilersForums.com
mcgtech
