Discuss Removing Squaredged tile-trim. in the Canada Tile Advice area at TilersForums.com.
macten
1,158
Nottingham
Cut from the top like Bob said. Don't need to prising anything out
smokie899
598
How's about buy more trim, a nice border tile and make a nice feature of it.
I done it in my bathroom with a vertical feature tile and metal trims separating feature tile from the rest.
Bond
518
Highland
I think go with the angle grinder,angled at approximately 45 degrees aiming for back (wall edge of trim) , and finish into corners, with multi tool with metal cutter blade, or dremel with cutting disc. - if you have one.
Cheers.
JerryB
I think the last post is saying cut through the base of the metal trim from the untiled side - sounds like a good idea. But still leaves the cut metal bonded to the tile edge. I'd cut a slit through this adhesive with a dremel type tool with thin diamond blade (got a set of these for £7 recently).
Reply to Removing Squaredged tile-trim. in the Canada Tile Advice area at TilersForums.com
