Removing old adhesive from chipboard Floor
AndyLFC5
Doing a Bathroom and en-suite, have removed old adhesive from en-suite with SDS drill with chisel (tried a floor scraper but nothing doing) and plyed out. Dont fancy repeating this in the bathroom though as a lot bigger, any alternatives, dont surpose you can use floor leveller as going onto chipboard so will probably just crack, would I get away with just putting ply over old adhesive (pretty level) after removing any big lumps?
use arditex latex leveller,,great for ply........dave..
ARDITEX
Size (pack): Powder 22kg, Bottles 4.8kg
Coverage: 1.9kg of mortar/m²/mm, i.e. approx 5m² per unit at 3mm thick.
A universal sub-floor smoothing compound, ARDITEX is used for the preparation of cement/sand and concrete screeds, quarry tiles, asphalt, granolithic or terrazzo floors and timber. ARDITEX is partially self-smoothing and can be used under a damp proof membrane.
Suppose you could lift the floor then re ply with marine 3/4". Probabky much easier to use the self leveler!
ARDITEX
Cheers, can you get this in topps (got an account with them) and hope its not as expensive as Fast Flex aka Liquid Gold
i get mine at CTD .as for topps i dont think so but gaz@topps will let you know if you ask him....its about £25 a go..............dave..
AndyLFC5,
DHTiling,
AndyLFC5,
DHTiling,
