Discuss Removing lining from ceiling in the UK Tiling Forum area at TilersForums.com.
F
fiona2367
Hiya everyone
I'm just a DIY'er...and have now embarked on removing the lining from the ceiling, as advised by our recent plasterer as there were a couple of areas where the lining was peeling.(there are also a large amount of cracks, some running the lenght of the ceiling and others across the corners)
I've started and it was going ok'ish with the lining coming away clean to reveal the plaster in all its glory. The problem I have now is that the lining isn't coming away clean anymore, which is making for particularly hard work as I'm not using the steamer. The plasterer advised me not to use the steamer as it would probably ruin the plaster under.
I've no idea when the plastering was done but we've been in the house for about 9 years so suffice to say its not new plaster but looks good (to my very novice eye).
any suggestions....would damping it down help?
Fi
DHTiling
You could try that fiona.....if not use the steamer but only in short bursts , so as not to blow the plaster with too much heat....but try wetting it 2 or 3 times allow to soak and try that first..
marc1106
use a liqiud stripper Add to warm water and soak with a sponge leave for 5-10mins soak again itll lift right off! polycell do a orange liquid remover thats my personall favorite! :45:
F
fiona2367
....when I do the soaking...should that ideally be onto the" leftover" lining rather than onto the painted lining? I assume the former but then again if I'm using the polycell stripper it'll "eat" throught the paint so I won't need to remove that "first" layer??
really sorry if this sounds a bit daft!! I've stripped many a wall but ceilings are a new game!!
thanks again to all who've answered / will answer!!
F
DHTiling
If you can fiona pull the top painted coat off and soak the backing to get it off.......back aching work but will be worth it..
marc1106
And if you cant pull the top layer off score it with the corner of your scraper, this will help the "stripper" soak through to the backing! :45:
F
fiona2367
ok.....the top layer is coming off nice 'n slowly....there's no backache yet it's the lower arms that are aching already!!!! Any solutions to this....lol
Right, back to work I must go....need to impress my dear man with my hard work y'know!!
:hurray:
Colour Republic
You may have already stripped it by now, but before I make any suggestions on how to remove the paper quicker. do you know how the ceiling is contructed? how old is you house? is there a chance it could be lath and plaster? or is it moden plaster board?
Reply to Removing lining from ceiling in the UK Tiling Forum area at TilersForums.com
