Stef
Ok following on from a previous thread,
PVA is not acceptable to be used as a primer in a tiling situation.
There are designated primers out there that the adhesive company's have spent a lot of money on to make sure they work along side the adhesive to give it a proper key into the substrate.
There is plenty of information on this forum to see why not to use PVA.
It's not acceptable to state "I've used it for years without a problem"
There's no if, buts or maybes, it's not suitable.
The adhesive manufacturers have proved that tiling to PVA leads to failures in a tiling environment so why risk it???
PVA V Primer
This is the only place you should see PVA.
PVA V Primer
