Currently reading:
Polished marble sealing
Discuss Polished marble sealing in the Australia Tiling Forum area at TilersForums.com.
ailsa
There is no need for confusion or problems brought about by misidentification of a surface type, yet it happens all too often. If you would like to see why this is the case and how to properly identify a surfacing material.Marble Polishing Process' reduces disintegration and crumbling of the surface under hard mechanical wear and weathering. The surface becomes approximately 10 times harder than an untreated marble surface.Surface is very smooth and not very porous
Polished crystals bring out brilliant colors and grains (400 to 3500 grit to polish stone)
Shine comes from the natural reflection of the stone’s crystals
Polish can wear away due to heavy foot traffic and improper maintenance
jonnyc
Sounds interesting . Can you explain in layman terms . Misidentification is a wire I would love to use
Lithofin BOB
518
Hampshire
Although the surface is polished, there is still generally always porosity, by saturating the impregnator for a period of time depending on each porosity of different stones , this will give the product an opportunity to go in to the polished finish and give the water and oil protection.
Ie, I soak each section I impregnate, for different times , very hard dense polished granites up to 20-25 mins /polished marbles - 10-12 min .
I will always test a spare stone, or in a discreet area for this timing, see how your stone reacts, does it go straight in or does it just sit up on top. This test then determines my saturation times for each section or stone type.
The most important part of impregnation is then to remove the excess, any product not taken in to the cappillaries must then be removed, I use old white towels to then buff the surface fully dry , before then moving on to the next section. Don't leave polished stones with a wet look finish, this can then cause you problems, smearing, dullness.
So, where does the sealer go? You remove it
Reply to Polished marble sealing in the Australia Tiling Forum area at TilersForums.com
  • Sticky
