jonathandrewe@g
Hi All,
I'm new on here so please bear with me if I've put this in the wrong section!
I need a 760mm shower tray, door and shower mixer unit for the week beginning 8th Dec. Firstly where is the best place to get these? And secondly does anyone know if it's better to go with an electric shower off the cold supply or a mixer off hot and cold? The boiler is a gas combi and water pressure is good, but apparently reduces in the existing shower if someone flushes a toilet... I explained that if I fit an electric or a mixer, because they have a combi, the pressure drop will be the same, is this correct?
Also which is a good quality door please, because I fitted one last week (client supplied) which was a rubbish design (The chrome trim below the door sticks to the tray with Silicon??) it left me thinking it was sure to have problems...
I'm installing it into a cubicle which will be formed from 3 stud walls and then tiled inside. I was planning on wedi board lining the studs first, but any tips on cheaper alternatives would be very welcome... I see some people stick to moisture resistant PB in these situations, or should I stick to wedi?
Any advice greatly appreciated
Jonathan
Jonathan
