BOFH
Hi guys, we have a wet room to do and it's not something I've done before so I could use a few pointers. The room itself is a triangle of sorts and the shower will be sited at the pointy end
The room is upstairs in an old property over 7x2 joists. I intend to nog out the joists then ply line the floor and walls, then use some type of tanking material to line over the ply before tiling.
If this is a suitable way to go then I'd like some advice on what type of material to use for tanking and the adhesive I should be using with said material. I'm not sure at the moment regarding the type of tile the client has chosen, but the size will be 600x600.
Any tips and advice folks?
