Just moved in. Properties only form of heating is electric underfloor!! COST?
Ashleynorris
Hi all,
I have just moved into a new apparment, its around 8 years old and was made with underfloor heating as its only heat source. We have living room large hallway and 2 bathrooms 2 bedrooms. The place was freezing when we moved in as it was inhabited for months.
Each room has its own thermostat (devireg550) we turned them on and it was still freezing so we raised the issue with the seller who insisted because its concrete walls and floors it takes ages to heat up you need to turn it on and leave it. So i have got the living room and hallway on constant set at around 15degrees and these areas are livable but the rest of the apartment is freezing . I have been watching the digital electric meter and been trying to workout cost not sure if im reading correctly but it would seem im burning tonnes of electric for a one level appartment which is still in my eyes freezing !!
With the flooring taking so long to heat up i cant imagine it would be cost effective upping the temperature and having it on timer.
Im reading the meter and subtracting the previous reading and assuming the difference is KWHS. In that case i would be using 65kwh per day which seems shocking, we dont have any plug in heaters running and no tumble dryer. we came from a 3 bed semi house with gas and i was using around 800 a year combined and was always warm.
Am i reading the meter wrong or is this heating that expensive??
Sorry for the lengthy post.
Any advice would be great .
Welcome. I can’t comment on running costs, but I can tell you the most effective way to use it is to keep it ticking over on a moderate head and just increase a few degrees at peak times. What is the floor covering ? 15 degrees isn’t enough, you want to be running the floor temp at high 20s.
Yes it’s expensive!
The sales spiel say about 1/2p (halfpenny) per metre per hour to run .
Doesn’t sound much but a 12sq mt floor would be 6p / hour x 8hours = about 50p /day so £15 month.
I have electric Devi mats on 2 floors about that size so £30/month. I set the floor at 18-20 degrees and leave them on in winter. Depending on your insulation it can take an hour+ to warm up but the floor sensor will switch it off once reached - hence it should only be on/ heating up for 8 hours or so.
I think it’s great!
Hi,all.
Thanks for your prompt reply. My floor space is a total of 60square meters. I only have the heating on in the living room (24 square meters) and the hallway 10 square meters approx.
Am i reading my meter wrong then or am i correct in reading it and subtracting the previous reading and using the numbers left as kwh used??
Regards
Ash
Hi Ash,
I can't say I know anything about electricity meters but, so long as your reading whole kwh numbers and not fractions of one, it's got to be correct.
Also, if you have 34m2 of 200w per m2 on for 8h(forgetting the switch off when its up to temp) its 54.4kwh. So, your 65kwh(aprrox £8.45) sounds in the zone.
Do bear in mind how cold it is at present mind so, heating systems are using up alot of fuel.
Hang on a sec! Why are we assuming it's standard underfloor cables? Only an idiot would use it as the sole heat source.
Even though deviregs are used, they could be controlling in-screed cables. Something more efficient than standard mats or cables.
Hi Ash,
Thanks for the info mate. Yes i was worried it was correct lol as it does seem very expensive. I wouldn't mind if i was sat her in shorts and a tshirt but with the hallway and living room on approximately 15 degrees its still so cold yet im going to be paying a fortune. it doesn't help as i only moved in one week ago which happens to be the coldest week in history so lets hope when we are back in usual UK temps my consumption will be far less.
Cheers for the post
I have no idea what system it is all iknow is its a block of 6 flats built in around 2006 with only heat form being underfloor heating with devireg controls in each room and hallway. I was expecting it to be expensive but if i am using 60kw per day with just 2 rooms operating then its costing me £10.00 per day approx . For a building thats still very very cold
NOT HAPPY to say the least. Its my first owned property after years of renting and this has put abit of a downer on it.
What floor coverings do you have as this can affect heat radiation
Tiling on Underfloor Heating
Ashleynorris,
Ashleynorris,
Ashleynorris,
Ashleynorris,
