Isomat Isomat UK Sealants and Adhesives
I
ISOMAT UK
Domosil - High-performance, general-purpose Silicon sealant for sealing joints 3 to 40 mm wide, on surfaces of non-porous materials such as glass, aluminium, porcelain (e.g. tiles), ceramic etc. It cannot be over painted.
Data Sheet Click Link
Domosil-s - High-performance, mildew-resistant Silicon sealant for sealing joints 3 to 40 mm wide, on surfaces of non-porous materials such as glass, aluminium, porcelain (e.g.tiles), ceramic etc. Also suitable for applications in high-moisture sanitary areas such as bathrooms and kitchens, as well as in hospital areas, laboratories etc. It prevents fungal development that creates stains and black spots. It is not recommended for aquariums since it contains fungicide. It cannot be over painted.
Domosil-Micro - High-performance, anti-mould Silicon sealant with built-in Microban® antibacterial protection technology. It remains colour stable even after 10 years. Appropriate for sealing joints of 3-40 mm wide in non-porous materials, such as glass, aluminium, porcelain and non-porous ceramics. It is applied in high-humidity areas, such as kitchens, bathrooms, etc. It is not recommended for use in aquariums and cannot be over painted.
Domosil-Pool - Silicon sealant resistant to permanent water immersion, such as swimming pools, aquariums etc. Appropriate for sealing vertical or horizontal joints 3-40 mm wide, for indoor and outdoor applications. It has very good adhesion on surfaces such as glass, porcelain, aluminium, ceramics etc. Suitable for sealing joints on boats, glass structures etc. It cannot be over painted.
Flex PU-20 - One-component, solvent-free polyurethane sealing mastic. Ideal for sealing joints where high elasticity is required. Suitable for joints in concrete, brickwork, natural and synthetic stones, steel, aluminium, wood, ceramic tiles, rigid plastic etc. For outdoor and indoor application.
Flex PU-40 - One-component, solvent-free polyurethane adhesive mastic sealant. Exceptional adhesion to all building materials, e.g. concrete, brickwork, natural and synthetic stones, steel, aluminium, wood, ceramic tiles, rigid plastic etc. Also suitable for bonding these materials. For outdoor and indoor applications.
Flex PU-30 S - One-component, polyurethane adhesive mastic sealant with solvents. Ideal for sealing joints where high elasticity is required. Suitable for joints 5-50 mm wide in concrete, brickwork, natural and synthetic stones, steel, aluminium, wood, ceramic tiles etc. For outdoor and indoor applications.
One-component, polyurethane adhesive mastic sealant with solvents. Exceptional adhesion to all building materials, e.g. concrete, brickwork, natural and synthetic stones, steel, aluminium, wood, ceramic tiles etc. Suitable for joints 5-30 mm wide. For outdoor and indoor applications.
Isomat
ISOMAT UK,
ISOMAT UK,
