Is there a tool?
jaydebruyne
To remove tiles without breaking the tile?
I'm a plumber (new to the trade) and often I have to remove tiles from boxing or walls to gain access to toilet cisterns etc. If I'm lucky, the builders have tiled a lid and siliconed it together but I'm not always that lucky.
I had to get to a concealed cistern the other day and couldn't save 1 single tile on plywood boxing :yikes:
Any help/suggestions would be grand!
Cheers
yes there is a tool for that,karl dahm fliesenentferner pro fix art no.40981/40982
that's cool
how does it work.
all the links iv found are in german.
im guessing that tool sticking out of the top creates heat that debonds the tile
And would probably cost more than the bathroom suite
how does it work,remove grout around the tile adjusto the unit to suit the tile place in the clean grout lines turn on heater for about 8 min. at 600 degrees then remove the unit and lift the tile.do the repair and put the tile back.
This is what Google translate suggests:- Seems quite a novel idea, I wonder if it works?
The Fliesenentferner ProFix remove non-destructive laid tiles you can use after execution of redevelopment of the ground again !
The Problem:
If a damaged area is under the floor tiles or a core hole must be drilled , it has been the rule , to destroy the affected tile and replace on the design of the renovation work .
A particular problem with rare tiles or older decors that are to be procured no longer or only at great expense .
The solution:
With our Fliesenentferner ProFix You can record most tile destructive and running again after execution of remediation .
The system chamber , depending on the model, all standard tile sizes to 30 or 50 cm size - to be adjusted - square or rectangular.
The Fliesenentferner ProFix has handles are not thermally conductive material - so the heated chamber system can be removed without gloves from the treated tile.
The hot air blower is continuously adjustable from 25-600 ° C set (2300 W).
To remove a few steps to the tile from the floor :
1. The tile is exposed with a joint cutter . We recommend our cement and Silicon joints Schneider Art 41810 or complete our Nasstrennset Art 40690.Nach removing the joint it is filled with water.
2. The Fliesenentferner ProFix to fit the size of the tile to be removed , placed and heated with hot air blower .
3. After about 8 minutes, the tile from the substrate replaces .
4. grants you can easily remove the tile.
5. After the renovation or examination of the background , you can use the tile again .
Is there a tool?
jaydebruyne,
andy8758,
jaydebruyne,
andy8758,
