Important Changes to Tiling Standards
I think it's a shame that someone uses a nationwide firm to do some work which wouldn't be cheap and ends up with a below par job.
We know better and have hindsight but I think as a customer you kind of expect wickes to be offering more than Joe blogs tiling services from the yellow pages.
Absolute rubbish from wickes and their excuses are as ill-thought out as the set out.
I'd love to have a chat with whoever is in charge...
You would think so wouldn’t you! Unfortunately they don’t seem to be very chatty😛
Have you thought about getting a report from The Tile Association done? Not sure of the cost off hand.
Sorry, bit late to the party on this one, but here goes:
BS5385 part 1-2018 - 7.1.5 Setting out
Unsightly cut tiles should be avoided
and joints should be of a uniform width, true to a line, continuous without steps: allowance should be made for an adequate width of joint. Cut course, both vertical and horizontal, should be:
a) kept to a minimum
b) determined in advance
c) as large as possible
d) arranged in the least prominent locations
Where wall surfaces are interrupted by features, e.g. windows, access panels or sanitary fittings, the tile fixer should seek guidance from the designer as to the setting out to be adopted; similar guidance might be required in the positioning of movement joints, since they are predominant and could determine the setting out pattern.
Horizontal joints and cut courses should be positioned depending on several factors, of which the following are examples.
1) Tiled areas that adjoin or are adjacent should be set out so that horizontal joints are aligned
2) The upper and/or lower extremities of the wall might not be level, requiring a course or courses to be cut with a raking edge. Wherever possible, the horizontal joints should be positioned so that the whole of the rake can be taken up within the height of the tile in the cut course.
3) If it is thought desirable to align a joint with a feature, this becomes the setting out point and might initiate the need for, and frequently dictate the location of, cut courses elsewhere.
4) To ensure the rows are truly horizontal, a level line should be established to position the starting course. This line should be continuous across all tile surfaces.
Who are you feeling with is it the fitter or the contracts manager . Are you speaking to him or communicating by email, are you copying in the branch manager ,
Unfortunately the fitter has washed his hands of it. What happens next is remedial fitters come to complete snags, arranged by Wickes customer services. As I listed a number of issues including tiles and items that have not yet been completed then it gets escalated to customer relations who is the go between. They are liaising with the installation manager who is the one who said when he came to inspect that it is British Standard to start with full tile at bath and that he believes that this is acceptable work. He doesn’t respond to their emails and just doesn’t seem to care. If they phone me I follow up with an email. Wickes guarantee all of the work so my beef is with them.
“Fitter’s washes his hands of it”
How can he, surely he is the one responsible as he was the one who fitted it.
Thank you so much Paul, and the party is still going strong 😛 , will definitely be sending this information to them. You have all be such a great help thank you!
Tiling Standards
Matty A,
Matty A,
