How to prep broken plaster?
A
ag1975
Got a bathroom wall to tile next week with bits of the old plaster coming off. Top skim in some parts and down to brickwork in others. The wall's not all that bad but what's the best way to prep before tiling with ceramic tiles 75 x 50mm?
Cheers.
Strip it all down and have it replastered. At least with new plaster you can be sure of a more sound surface. Remember to allow it to fully dry first. Alternatively you could strip it down and glue up some plasterboard for a much better surface.
Is there any alternative to plasterboard or plastering? Can it be filled with something like easi fill and tiled onto???
You could fill the holes with rapid set but if some of the plaster is coming away then I would be worried tiling over it!
The plaster came away with the old tiles, but most of the wall seems ok, no other loose bits. If it was up to me I'd have reboarded with backerboard, but it isn't.
Just been looking at Thistle hardwall plaster...would this be any good?
Holes aren't too deep, maybe 5mm at most in places. If I did use rapid set could I prime with sbr?
Don't use Hardwall, you would need to use Thistle Bonding for small areas of making good but brush the area with sbr first to stop any suction from the back ground...
Or as above.
ag1975,
Peter,
ag1975,
Peter,
