Discuss How do you get clean grout lines? in the UK Tiling Forum area at TilersForums.com.
L
Lisamoore
Hi Guys,
I haven't been tiling long and have been told/seen 3 different ways to obtain clean grout lines.
Not sure if all/any are OK or it's personal preference but thought I would ask...
1. After applying grout, wait 15 mins ish and then run your wet finger down the lines, wait 40ish mins and clean off tile.
2. After applying grout, wait 15 mins then use clean sponge in light circular movements to get a smooth finish on grout lines. Wait 40 mins to clean tiles.
3. After applying grout, clean off tiles using light circular movements followed by diagonal wipes?
Any advise would be appreciated!
Lisa:juggle2:
Mike
it's hard to determine how long after applying to wash off as there are a lot of factors in the equation, i.e type of substrate, room temp. type of grout, width of gap and type of tile. a ceramic will absorb the moisture out of the grout thus drying the grout quicker whereas a porcelain won't. it's always best to try a small area first and see how it dries. as above a washboy is good for cleaning and smoothing the grout lines
R
Rich
The timing will depend on the grout, the tiles and the atmosphere so you are better off just keeping and eye on it, you will soon find that you know exactly when to wash off.
I apply the grout and every 10 mins or so I check the grout in the joint where I started to make sure its not going off on me. When it is just starting to harden, give the tile and the joints a gentle wash off with clean water and a clean sponge, if the grout is pulled out of the joint then it is to soon and if you have to really scrub at it, it has been left to long.
skeg
This is all great advice. I'm also new to tiling and struggle to get grout lines that i'm completely happy with. As suggested by someone else on here i'm probably washing the tiles too soon which is pulling some of the grout out. It is definitley a learning curve. The last tiles i done were on our splashback in our new kitchen and the tiles have got a matt kind of finish. Didn't leave the grout too long before trying to wash of but had already started to dry on the matt surface but was probably still too wet in the grout line itself, right bugger it was!
495
1,098
Somerset
Hi Lisa and welcome.
Treat grouting as a "process driven task" and each stage is determined by how the grout is drying. You need a flat smooth sponge, and I recommend 2 buckets of water if you do not have a washboy.
1. Apply grout using a rubber edged applicator. Push into joints with the first stroke, then using the blade/edge of the applicator, wipe diagonally across the joint to leave a cleanish finish.
2. After applying grout to about 1 square metre of tiles, soak the sponge, then wring out most of the water. Wipe either in circular or diagonal motions across the tile joints KEEPING THE SPONGE FLAT at all times (so you dont pull grout out of the joints). Rinse the sponge off in bucket number 2. Then use the clean water bucket to wet the sponge again.
3. This time wring as nearly all the water from the sponge. Then keeping the sponge flat again, move it lightly and slowly across the tiled surface to remove as much grout residue as possible. Only wipe the tiles with the sponge onceduring this stage, and stop frequently to clean off the grout accumulating on the sponge using the 2 buckets.
4. Continue repeating steps 1 to 3 until all the tiles are grouted.
5. Let the grout dry for at least one hour. It is dry enough for final polishing only when you can make no impression on the grout when touching it with your finger.
6. Now get a clean cotton cloth and polish the grout haze from the tiles. 2 cloths are better than one for a really sparkling finish and perfect grout joints.
Good luck.
smidy69
i tend to apply the grout, leave it for a while (no set time) until it starts to go off, it can take longer depending on the conditions and the type of tile used so always go back over it and keep checking it. i then wash it in a circular motion with a good clean sponge and wipe diagonally. just make sure you keep your sponge fairly dryish after rinsing. with plenty of practice you'll get the hang of it in no time.:smilewinkgrin:
TheTiler
Apply your grout with a proper grout float (solid handle and rubber face - not a spatula DIY piece) on a couple of tiles in a test area. Leave for 10 minutes and use a quality sponge purchased from a tile shop (Ardex sponge is my favourite) to wipe off (after taking all possible moisture out by hand-wringing) with firm diagonal strokes to start with and then follow up with light in-line strokes to joint directions to ensure smooth and seamless grouting. If this works for your test area, then increase the next area, and judge the drying times of your grout - you want it to be firm, but not set before sponging. Run your finger down a joint to see if it holds in the joint, but doesn't displace much, but firmly smooths instead. There is a difference of only minutes in capturing the right time usually, although porcelain always takes longer to achieve this than ceramic biscuit which can be very rapid in drying out grout. After finishing, allow to dry until the grout cannot be disturbed by anything other than poking the joints with a sharp edge and buff away minor films using an ordinary white towel.
Reply to How do you get clean grout lines? in the UK Tiling Forum area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
