Discuss How can I clean dark brown grout stains from a light beige porcelain tiles? in the UK Tiling Forum area at TilersForums.com.
Soyabean
Hi enduro, thanks for the offer but I am based in Barnet in North London/Hertforshire borders. Sounds like you have had some experience in this kind of situation? What do you think the chances are of getting it removed? Thx
Brinkley
enduro would a grimex type thing be strong enough sounds like yhe grout has got into the pores to me
E
enduro
Was thinking about Aquamix Sealer & coating remover, but it is quite expensive if i does not work. Have a go at putting nail varnish remover onto the stain, as this contains acetone as it may work. I have used it on stains before and it has removed them.
Soyabean
Thanks enduro. will give the nail vanish remover a go now. Will post a reply to the results... Thx!
Soyabean
Right I couldn't find the nail vanish remover but did find some surgical spirit which I am sorry to report didn't help. I have an offcut with the same thing done to it. The grout was only put on it to show me the effect so it's not as stained as my real tiles but at least I have something which I can try the surgical sprit onto as soon as I leave the shop. Will update with my results. Thanks
TheTiler
I will back up Soyabean. Acetone often works, although sometimes a toothbrush is needed and a LOT of time. I've had a couple of miserable experiences with riven porcelain and polished porcelain even after I'd asked advice from the suppliers PRIOR to fitting. I had one job where the manufacturers of some polished white porcelain explicitly explained that the tiles required stripping off a manufactured wax coat with a Fila stripper prior to fixing and then sealing (with Fila). Then fix and grout and seal again (with Fila). Understood, I thought, however, once the factory wax is removed, it's all up to the sealant, and although you may follow it to the book, I managed to stain a couple by rubbing a knee pad on them during fixing. Took me forever to get it out, and I still had to warn the customer to never walk on the tiles in shoes. Some tiles aren't fit for purpose methinks...
Soyabean
Hi all I just wanted to say thanks for all your tips and advice last night. It gave me hope. Tonight I am much happier as my builders team managed to get the stains off of the tiles.
I just wanted to share the name of the cleaner. It is called MGP 30 is acid based and here is what I found out about it from the web "MGP 30 Cleaner for removing sealing residues from porcelain grès and natural stones, and concrete residues from slate; especially recommended for cleaning cobblestones, rosettes and ancient-finished marbles."
It has discoloured the brown grout in places next to the tiles but I can live with that. Last night was a nightmare; by comparison this is just an shame.
There must be things I can paint onto the grout to make it look brown again right? And if not, never mind. At least my lovely new tiles have not been ruined :)
Any of you heard of the MGP 30? And if not it may be worth looking up just in case… Cheers all!
johnryan
just get a grout rake on the stained grout, and regrout it.
edit; very carefully regrout it i mean.
Reply to How can I clean dark brown grout stains from a light beige porcelain tiles? in the UK Tiling Forum area at TilersForums.com
