Discuss Hardiebacker confusion in the DIY Tiling Forum area at TilersForums.com.
38
Keighley
Appreciate the responses, I think I'm going to return them. They are from b and q so should be fine.
I'm struggling to find any stockists nearby for marmox, wedi or jacko boards.
I know I can get nomoreply which can be dot and dabbed. If hardiebacker was going to need to be tanked anyway which again I didn't realise, can I just use moisture resistant plasterboard and tank that? Or is it not recommended for shower areas?
F
Flintstone
If space is limited for building out, you might as well stick with the hardie backer dot and dabbed as its 6mm thick and not 20mm like impish suggested. You can actually dot and dab with 12mm thick wedi type board tho.
F
Flintstone
Ahh. I’m not too familiar with the hardie backer ways but no more ply you can dot and dab 6mm. I can’t see why hardie is any different
One Day
20mm for spotting on walls. If you use thinner, there's zero come-back. Wedi, Delta, Jackon - all say 20mm
https://www.wedi.de/fileadmin/media...Building_boards_-_interior_GB_2015_SCREEN.pdf
(page 16)
As for 6mm cement board on walls... not for me thank you!
One Day
Ah, marmox is one manufacturer I've never used.
I know their coating is a little tougher than others, maybe it helps?
F
Flintstone
Maybe it does help, maybe there more confident to say 12mm is fine. 12mm is pretty rigid, I can’t imagine it causing any issues. I find the coatings can be quite inconsistent on various board manufacturers boards.
Reply to Hardiebacker confusion in the DIY Tiling Forum area at TilersForums.com
