Discuss Grout line thickness in the UK Tiling Forum area at TilersForums.com.
If the floor is as smooth as glass and all your tiles are exactly the same size then you might get away with it but I have yet to see those conditions. I dont like to go below 2mm.
i here alot about british standard, but is this the law?
It's not the law, as you can do whatever you like in your own place, BS5385 parts 1-5 are guidelines for a proper tiling job and usually required more in the commercial sector, however, myself, and Im sure, a lot of others on here do our tiling to BS5385 anyway for peace of mind and no comebacks.
i dont meen to be funny with you but your first reply conficts with this reply dont you think?
As above, 3mm min joint the bigger the tile the bigger the joint imo. If I am working with a 600mm x 300mm I would go for min 3mm joint, better still 4mm, for expansion reasons. The more tile area the less joints. Less grout to accommodate lateral movement
Reply to Grout line thickness in the UK Tiling Forum area at TilersForums.com
