Grout Haze - how to get rid of it
MrT
Hi
How do you get rid of this?
Do you just rely on water, or do you use a grout haze remover?
I have got the Vitrex polishing sponge, but the haze seems to remain.
Any advice appreciated.
Cheers
Mr t, it should wash off without any chemicals unless the tiles are textured or you have left the grout too long and it’s stuck on thick
Given it two rub downs with water.
Most of it has gone, but just wondered if there was a quicker way as the room is big. (7m x 4m)
I’ve always found bal to leave behind some polymer if not cleaned thoroughly and quickly.
A white emulsifying pad with hot water should pull it up.
Then a good buff with a cloth.
Try this first before moving on to grout haze remover.
DIY Tiling Forum
MrT,
Tommcd,
MrT,
Tommcd,
