Currently reading:
granite tiled worktops
Discuss granite tiled worktops in the UK Tiling Forum area at TilersForums.com.
dexion7
Hi guys - newbie so go easy on me please!.
i'd really like to fit start galaxy granite worktops in my kitchen but the cost is too much.
tiles are available much more cheaply than complete tops and i wonder in anyone has tried using these in a 'diy' fashion to make a worktop. 600mm square size tiles are freely available and since the two worktops i need are both straight with no edges to finish i'm considering giving this a go.
my idea is to fit them on 18mm ply and butt them so i guess it would be a case of ensuring that they are exactly square and flat. the visible edge would be stainless steel strip (to match the carcass doors) bonded with epoxy to the edge of the tiles/plywood.
any ideas or comments welcome.
dexion7
liquid and food bits will seep into joints harbouring bacteria. Can't see a problem otherwise though:thumbsup:
when i said i was going to butt them i meant joining them by coloured epoxy with no designated gap between the tiles (usually there is 2-4mm when they are used on the floor)
the question about the viability of butting them realy centred around the liklehood of them being a) square, b) of constant thickness and c) do the tiles have a bevel on the edge.
what would be the best adhesive to stick the tiles to the ply?
thanks for the replies fellas
P
Polishtradesman
hello dexion
in my opinion what you trying to do will not gonna look nice, i would save bit more money and would buy slab of polished galaxy granite, you could cut granite with grinder and finish it off with diamond pads, you can buy pads from trimline
good luck
I would not butt them too, you must leave gap between tiles to put grout into. (epoxy wiil be the best for such a place, cement grount class CG2 is not good for worktop for sure). You must use adhesive class C2 to fix tiles to ply. Best idea is just save a little more money and do it nice with one piece.
biffa
Hello and welcome
I did this myself in a hairdressing salon. Laid 100m2 of star galaxy on the floors and made worktops with remainder.
Used 18mm ply double thickness, glued and screwed, so finished thickness is about 50mm. stuck them down using a 2 part flexible addy (Fastflex). grouted in microcolour black. its used for mixing hair colours.
2 years on still looks the same as the day i did it
Reply to granite tiled worktops in the UK Tiling Forum area at TilersForums.com
