Discuss General tiling options in the Canada Tile Advice area at TilersForums.com.
88
Bedfordshire
I had an awful tiling job recently in my kitchen dining room areas (24m2). All will be coming up and I am now considering all my options, including UFH. The rooms are connected.
can anyone tell me my best options in terms decoupling mats, insulation boards, electric mats or loose wire? I appreciate this is a very general question. I was wondering if it is common to use both the decoupling and insulation boards? If I use either will that negate the need for latex if required?
J Sid
Without doubt I would recommend insulation board and as thick as your heights will allow. SLC over the wire, I prefer loose wire, other will prefer mat, and with porcelain no real need for an uncoupling membrane but is an extra insurance if you can afford it.
This is assuming your base is sand and cement
Boggs
1,118
Uk
I would be looking at Ditra Heat or Warm Up DCM Pro.
88
Bedfordshire
When you say level, is that the latex self level compound? It’s probably very obvious but can someone describe to me what benefit this will give considering there will be insulation boards etc? I have a brand new house and given it’s not perfect, it still looks pretty level.
Reply to General tiling options in the Canada Tile Advice area at TilersForums.com
