F
Flintstone
Can anybody offer any suggestions on anternative to diamond cup for 180mm floor grinder? I’m after something less harsh for fresher screeds that need a lighter sand..
this is in my garageSorry Andy didn’t see this.
60# copper sanding disc. Don’t ask me where to get one. 🙂
yes type ones to attack the glass paper sheetsThanks chaps do they attach to a backer with a flat nut in the center ?
those in copper are tungsten carbide.Not sure what you mean by tungsten carbide pads? Id like a durable solution, do the copper discs last a while or do they wear fast like a paper disc does
I've used sandpaper on fresh ones with success Andy. I've only ever had alpha hemi hydrite ones though if that makes any difference. Interestingly, I've just seen a statement from Knauf, who supply the raw material for the ones I get, that the alpha hemi ones mayhew easy screed do don't need sanding!Perhaps I should try some 60 grit sandpaper first and see how that goes
