Currently reading:
Fixing to Calcium Sulphate Screed & drying times
Discuss Fixing to Calcium Sulphate Screed & drying times in the UK Tiling Forum area at TilersForums.com.
wetdec
Using an anhydrite screed is not a problem provided its treated correctly.
When the screed is dried out properly( to 0.5% moisture), remove any latency with a scraper, wire brushes or sanding then hoovering up all dust.
If you have a wet under floor heating system installed increase the temperature in incriments until full heat is reached then work backwards, this procedure helps in the drying process of the screed and aids curing.
When dust free use your adhesive maufacturer recomended sealer to seal the floor, this protects the screed and should be done in opposing directions to ensure coverage. It is important that guidence is saught from the adhesive manufacturer as the bond to screed is their territory.
Screeds move even after drying due to expansion and contraction especially when using wet under floor heating and can cause tiled surfaces to crack from latteral deflection. To combat this cracking an uncoupling membrane such as Ditra (1) or Dura-Ci membrane should be fixed before tiling.
Cut to size and laid using a flexible tile adhesive the membrane is easily tiled over. The membrane acts to protect the screed from moisture from above so should therefore be sealed properly. The channels in the membrane aid air movement over ufh and during adhesive drying.
(1)Please check Ditra for their fixing instructions
There are always questions re gypsum / anhydrite screeds, hope this goes some way to answering some of them. :thumbsup:
Ajax123
1,213
Lincolnshire
Hi Ajax - Thanks for the contact - will give you a call as I really need to get this floor down now. Based in Midlands 15 mins from Bham NEC.
Appreciated. Cat
That's bleedin typical as I was in Solihull and Coventry today -could ave called - never mind. Give me a shout tomorrow and I will do what I can to help.
Reply to Fixing to Calcium Sulphate Screed & drying times in the UK Tiling Forum area at TilersForums.com
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
