Guest viewing is limited
electric mixing drills
tiler burden
hi
i have a refina mm30 mixer for plastering that can mix 4 bags of backing plaster at a time. it is 1750w and i wanted to use it in the future so i could save on buying a rubi mixer. can you pros take a look at this ....... http://www.refina.co.uk/acatalog/Megamixers.html and see if its suitable for mixing tile adhesive....it will need a different mixing bit but if it can kill 2 birds without me having to spend more money then i'll sleep better tonight lol
cheers ed
he ed it actually states it mixes mortar..so go for it......by the way your link didnt work....
MEGAMIXER MM30 MIXER DRILL for plaster, render, mortar & screed
APPLICATIONS
finish & backing plaster
render & external wall insulation
mortars & epoxy
floor screed, latex & coatings
heavy bodied coatings & paints
mix quantity 4 bag
i think id be lost without you dave ;0)
tiling is a life line for me at the moment. i am not enjoying plastering one bit at the moment. i am reading and learning as much as i can so that i can make the transition permanent. so it helps when i dont have to spend anymore more on another drill :0)
thanks again dave...
tiler burden,
DHTiling,
tiler burden,
DHTiling,
