dried grout haze removal, trav and slate
shogun rua
hi,
whats the best tool to remove dried grout haze on trav and slate, these tiles have been inpregnated?
Any tips?
Cheers
Paul
lithofin cement away 1:1 with water will work, but you will need to seal after (at least 24hrs later of course) as the acid will break down the original seal.
sounds bad lol acid :lol: have you used it before?
cheers for the reply
no, never, ever
i have never been in your situation ever,not once, at all, ever.
ever,ever.
regards
lol its not as bad as it sounds
its not bad, if you know what to do!
cement away breaks down the haze and the clumps of grout, afterwards you are left with a RAW surface, hence the reseal after the water has dried out!
wear gloves, apply, leave 40-50 mins,use tool to remove stubbon bits, sponge, dilute, sponge, washboy wash, leave 24-48hrs, seal.
Job done.. and dont do it again!
clean up after yourself you messy pup! :lol::lol::lol:
shogun rua,
p4ulo,
shogun rua,
p4ulo,
