Discuss Dog tooth method / rebate in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
macten
Field tiles 12mm thick, mosaics 8mm thick. Wall dipping away at top too!
Used the dog tooth method with an off-cut of tile.
4mm difference + 2mm adhesive so cut it to 6mm:
Spread a load of rapid in rebate
Comb it with dog tooth
Let dry for 30mins and it will leave a perfect depth to tile on
Works a treat and saves loads of time, hassle and mess.
U
united
Excellent post, thanks for taking the time to share your photos and give the step by step :thumbsup:
SandyFloor
I've done the same thing but with plywood....a tile offcut makes a lot more sense. Why didn't I think of that? Excellent post:thumbsup:
Y
Yorkshire Tiling Services
Nice one,thanks for post,here is one of mine !
[ame=http://www.youtube.com/watch?v=hDsf9ZtZndw]YouTube - Bedding up gap for mosaics[/ame]
U
user123
Macten, that's a proper turn-on... really!!! :smilewinkgrin: :thumbsup: Weak at the knees... oh yes :hurray:
Diggy
Yep thats the way to do it. If doing horizontal border I usually cut some oddsy tile the width of the border plus what ever joint then once surrounding tiling is set remove and do as Macten does , works a treat and you can get the mosaic exactly to correct depth , be that flush or slighlty proud depending on your taste.
Me I like to leave it ever so slightly proud, just.
Diggy
danmasey
Isn't leaving 2mm for adhesive a bit tight? Or do people use a 3mm Notchy for mosaics?
Reply to Dog tooth method / rebate in the America area at TilersForums.com
Apatel
