do you always shape the grout?
E
essexsi
Hi chaps, first post except for course feedback.
Went for a look round topps at lunch time and saw the grout shaping tools.
Is grout shaping something you pros do all the time, or is it normally a flick down the grout line with the sponge when washing off?
Thanks for your input.
Si
Hi, if you want to shape the grout use your finger, also you don't wont to use the sponge as this could remove to much grout, always clean tiles at 45 degrees.:thumbsup:
Cheers enduro.
If in doubt stick your finger in. Thats got me in alot of trouble before!
When cleaning up we were shown to flick the sponge gently along the grout line, I suppose to shape it slightly.
So, am I correct that you should not leave grout flush to the level of the tile and should always shape?!?
cheers Si
The only times I ever use grout shapers, is when the customer requests something specific. Other than that, I normally achieve a perfect finish with my sponge float. I weat nitril gloves while grouting, so my hands are kept somewhat dry. I only ever use my fingers when there are small gaps in the grout; dabbing or redistributing some grout with a gloved finger.
I've got a grouting guide in my signature if anyone's interested.
Hi Si,
Hows Life going. well i always get a nice finish on the grout by using my sponge just a quick rub over not applyin alot of pressure. i find that it does the trick.
well Si hope the FB is ok
take care Pat
Hi Si,
take care Pat
I'm with you......sponge works fine( on walls), trick is not to have it over wet.......and i use a washboy on floors.........:thumbsup:
essexsi,
strongboes,
essexsi,
strongboes,
