DIYer doing 600x600 polished porcelein
thanks jay for the advise
i have a concrete floor, and its a brand new home, just 3 months old.
Just need to know if i use LASH leveling system
(QEP - LASH)
just need to know whether this would do any help to avoid lippage, and yes the concrete floor is almost flat.
Hello Peckers,
Thank you very much for such a good response,
Firstly I am in Brisbane, Australia so due to warm climate I don’t need under floor heated, more over it’s a concrete flat slab. Its been built by a good builder here, and its sort of very flat, any ways I will back check it as I go for the tiling bit by bit.
The total area I am covering is 140 square meters. I am using some, rubber adhesive which is ParexDavco: Australia
I was advised to buy this product from the shop where I bought the tiles from, about this product.
I will hire the dry cutter, and I have bought a small wet saw cutter with diamond blade.
Regards
any jobs going ? iam looking for a sponsor ? :thumbsup: :8:
I am not sure I am actually looking for a tiler, to do polished porcelain 600mmx600mm in brisbane
If you are dealing with porcelain then we supply the diamond cores
er.ronakshah,
Deleted member 1779,
er.ronakshah,
