Discuss different thickness tiles in the UK Tiling Forum area at TilersForums.com.
Daveyboy
That's good advice from Fred, Calle (or is it jasmin?)..but it's still tricky as you've got to keep the wall tiles bedded out the same horizontally and vertically, allowing for any bends in the walls..otherwise you could find you've not bedded out enough in some areas and too much in other areas..def try to get her to go for the same thickness border and wall tiles..:yes:
cmdceramics
London
lol ive just had the same problem, told the customer that it would be better to change the border so they went back to the tile shop and were told that the tiler would be able to pack out the tiles to suit and that all borders come in the same thickness!!!
They believed the guy at the tile shop. Thanks tile shop guy!
Tiler London
silver
Hi,
depending on how much to pack out and what the mosaics are (stone, ceramic or ...glass).
There are packing mats available..... basically spacer pegs (square) joined end on on a sheet at about 2>3mm thick..I have used these and they do work..you cut to size.....
If walls are bad and you are on thick tiles and thin mosaics a thin tile >6mm insert can work too. but glass will/could show this through and the addy.
I also express to customers to get similar thickness tiles to borders..probs arise around switches when customer is adament about border height (Kitchen), window recess with vertical trims, shower screen fittings etc....
I have lost count of a "good tiler will get round this" remarks.....A good tiler informs the customer about this and why....and before they buy where possible. I have had no problems with tile shops I use exchanging borders for this reason..they havent lost a sale and are found to be extra helpful...so they dont mind.
The customers just dont think that far into a job...why should they, they are not tilers...thats why we need to help them.
Reply to different thickness tiles in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
Hello I plan to tile our bathroom with 60x60 cm tiles (8 mm thick) and the shower (because of the slope from all sides) will be done with mosaic tiles (5x5 cm). After researching I came to the...
  • Question
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
