cut and shute
K
kent tiler
went too price up a job to day the old bath is choped into the wall lath and plaster its a small bath room how do i over come this problem
im stiping the the lot even the floor is going joists too (ground floor)
strip out all the room then the floor new floor too go in then the walls going up 12.5mm plaster board then the new bath sink bog all new plumbing totel max out all new wight b&q tiles 3m2
gray slate floor b&q tiles 4m2 its chip board t&g flooring 4#2 joist
the bath room is say no more then 6m2 floor too refit
its the bath is the prob its cut in to the walls cant move the walls HELP
It must come out, or are you saying this bath is original? i.e has been there as long as the lath and plaster?
Im confused, if your going to strip it all out joists and all why does that present a problem with the bath?
what i meen is the bath that is in there now is cut in too the two end walls 2ins both ends so what im saying is can i just get a smaller bath or do i have to go down the road of cutting it in to the walls iv priced it so i make money not spend too much out the bath set i want too get is the B&Q set think its bathroom suite to go £200 or so the white set and the problem i have is the floor and joists need replacing
so there is no bog think ill need to get a porter loow for a day or two :incazzato::incazzato:
the flat is a tip and stinks :mad2:
we dont know if you can get a bath to fit as you havent yet given us the length of the bath wall:mad2:
It must be a standard 1.70m bath, think you can get a 1.50m but not from the sheds though
cut and shute
Tags Tags
cut usa
kent tiler,
kent tiler,
kent tiler,
kent tiler,
