Best Grout Remover (other than FILA)
mmmadman
Hi all, I am using FILA grout residue remover and a scrubbing brush but carn't seem to shift the whiteish haze of my riven slate patio. Do I need to use a stronger solution or try something else.
Can anyone suggest something better/stronger and where can I get it from, it has to be plant safe as I will be washing some off onto the garden and the wife would not be happy if I kill her plants off.
Many thanks.............................:thumbsup:
You could use Ltp's grout stain remover, I used it last week and it worked brilliantly
LTP Online | Product Basket
As for the plants................be careful.
:thumbsup:
:thumbsup:
yep, gotta agree with you there Dom:thumbsup:
Thanks for the speedy replies, is it worth trying a stronger mix of FILA first or just getting the LTP is it only available online....?
Cheers.............
When I come to seal the slate, I already have some FILA slate protector is this as good as the LTP sealer or should I get a refund and use LTP?
Also where can I post a picture when its finished?
Cheers...............:thumbsup:
I would recommend checking how long the manufaturer states their product will last for, and make any decision based on that.
From memory, which isn't that reliable, I think LTP products are stated as lasting longer than FILA, by about 5 years. So personally, I would go for LTP. :thumbsup: Hope that helps.
some slates react to certain grout haze removers and you get a white bloom from the acid attacking the surface ,some grout haze removers are hydrochloric acid based others are phosphoric acid based some are a combination of both ,my advice would be to get a few different ones and do a test on an area that is not going to be seen and then use the one which works the best wtih out damaging the tiles :thumbsup:
Thanks all, LPT did the trick I have posted some pics in this Stone Tiling Forum of the finished patio...................
mmmadman,
mmmadman,
mmmadman,
mmmadman,
