mr white
Hi
I laid my first few tiles today, and I got a few questions after I feel I was not doing something and many things incorrect....
I'm laying 900x150mm wood effect tiles which I started from the centre of the room where a small area was 4/5mm higher than the rest of the otherwise level concrete slab.
what I'm not sure about is the trowel technique/ best way to apply the adhesive to the floor to keep the tile levels.
Should I be applying pressure to the floor so I achieve straight arches of adhesive which will be following the level of the floor (leaving noticable gaps where the concrete can be seen), or would I decrease pressure on the trowel in the area where the tile adhesive needs to be thicker? Or apply some extra adhesive to the tile direct where it needs more?
I just watched this
And it makes a lot of sense on why the direction of the adhesive applied to the floor is so important for strength, but I can't find info on how to apply adhesive to areas that require more adhesive on say one side of the tile/ or how to build a bigger bed etc areas that require an extra 4mm to keep level with the high point.
I'm probably over thinking it and I'm just really slow it at the moment, I had to pull a couple of tiles up twice and reset as I was way off on the level.
Also should I prime the floor again tomorrow before tiling dues to me walking over it and also the excessive adhesive I applied around tiles that I scraped off?
Sorry if the questions seem daft, but I would rather ask than create a nightmare fix in a few months!! lol
Any tips would be great!
Mick
I just watched this
Mick
