Discuss 72mm hole cutter anyone? in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
As Dave says just use the 70mm and open out the hole a few mm
Full project details can be read here
Basically:
1) Use the 70mm to make a hole
(Picture shows 80mm but principle is the same)
A perfect 70mm hole has formed
Ream out the hole with the side of the drill
Fit LED into hole...
Take things easy and you should have a perfect result
Most lights do have a recess or cover plate to hide the hole so doesnt have to be too perfect...
Deleted member 1779
Yes contact us direct if you need any advice.
One final thought....
On this project we did spend a LONG TIME honing out the tile to fit the lugs of the LED's
The smarter way to have done this project would have been to have cut off the PLASTIC LUGS with a stanley knife rather than to grind out the tile.
We actually spent too long honing the tile to fit the light. When really we could have made the light fit the hole...
Note to self: (Next time cut the lugs off !)
Not saying that its applicable in your case - but if you can benefit from our experience then it might save you a lot of grief? (Or others reading this post....)
Deleted member 1779
If accuracy is important to you - a holesaw will give you more control.
Result of drilling with a core: (hole shown 80mm)
However pjc is right - A diamond blade and a pair of nibblers would incur less cost.
The 70mm retails at £39+vat (Forum members get additional extra discount off this) and then its a case of working out how many holes you need in total. If you have 10 x LED lights to fit then I would suggest it will be easier to drill the tile.
Reply to 72mm hole cutter anyone? in the UK Tiling Forum area at TilersForums.com
  • Sticky
