Floor grout removal
Hi guys
What do you find is the best option for removing floor tile grout?
If it’s a multi tool, which attachment are you using and how long does it last?
Cheers
Paul
Hi guys
Cheers
Paul
By hand we dont risk damaging tiles and ive seen some right messes caused by electric tools
If you are careful and the area you are cleaning up is small, then a multi tool, diamond tipped blade is fine, plus another vacuum bag !!. For larger areas, or when tidying up a new installation prior to grouting, I use the Ox grout hand file, and the replacement blades are cheap enough. Plus it’s easy to use / control and you reduce the chances of damaging / scratching the tiles.
Floor grout removal
Tags Tags
None
Paul333,
Wesley,
Paul333,
Wesley,
