Discuss Tiling on sand and cement in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
H573
Hi all,
I’m going to be Tiling a large floor and two small bathrooms.
Floor substrate is sand cement screed/ wall is sand cement render.
I can’t get primer here at all( I could get something like previously but not anymore).
I got told previously on here that sand/ cement doesn’t need priming.
So do I just brush/ vacuum etc then tile?
Or do I have to dampen the substrate first ( after cleaning) then tile?
J Sid
Got to be completely clean, so vac and I'd damped it a little as you go. Before you trowel out put some adhesive on floor and use the edge of trowel to spread and work into the floor to get a good key
Dave
Hi.
As long as the surface is dust free and consolidated, then clean as you say and burn adhesive in before combing, thus creating a bond.
Out of interest how old is the screed and size of tiling field.
H573
Hi.
Thanks Dave,
Screed is about 6 months old. Total floor is 125m2.
Reply to Tiling on sand and cement in the Adhesive and Grout area at TilersForums.com
Apatel
