Discuss Limestone tiles colour change in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Jagweb
46
East Midlands
Hi, I have recently had Jerusalem Light Limestone tiles installed over a brand new wet underfloor heating system laid on the original floor (concrete over 10 years old). A decoupling mat was put down first. The appearance has significantly changed during the process of laying including severe cloudy patches. What could have caused this?
Spare Tool
Seems to be a reoccurring issue with limestone at the moment, not leaving them long enough to completely dry out seems to be the issue, notice yours are grouted so must have been sealed now trapping in the moisture I'd presume..
Jagweb
46
East Midlands
Just wondered what happens during the laying process that makes the moisture darken the tiles?
Spare Tool
The 6 litres of water mixed in with every bag of adhesive has to go somewhere, and as you've got an uncoupling mat down only place is up and out through the stone..
J Sid
Also most of these tiles are stored outside, even if the pallet has plastic around it it will sweat and the stone will take in a lot of moisture. That all need weeks of drying time after being layed before sealing and grout. Customers need to be patient, most out there sadly don't want to wait and then they end up with this.
Jagweb
46
East Midlands
Thanks for all the comments. So... if they are now sealed/grouted/sealed, will they ever dry out or is the colouring permanent?
[automerge]1567457731[/automerge]
thanks for the comments. The adhesive that was used was Tilemaster Adhesives Ultimate Grey C2 F S2 20kg. This is supposed to be rapid set - would moisture from the mix still have caused this do you think?
Dougs Third Go
they will dry out eventually but my guess is it will take quite a long time as the only evaporation egress will be through the grout joints, unless they were sealed too :(
Bill
Grey adhesive will not always discolour limestone........ before adhesive, limestone was fixed in sand and cement and that was hardly ever white!
Some limestones are more porous than others so you probably just need to wait.
J Sid
Jerry, didn't someone post on here that dural recommend S2? Read it somewhere
But I agree wouldn't use a S2 on mat.
Reply to Limestone tiles colour change in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
