New cutter(s). Need to practice now
943F954C-2062-4506-84F1-3441FAA54D7B.jpeg Following on from a post I was moaning about the amount of dust getting into the Bosch variable speed grinder and constant running temps when cutting and profiling stone I bit the bullet and replaced my old Flex variable which finally gave up the ghost with 2 new Hiltis, one variable 125mm and one basic 115 mm. Built more suited for constant stone work.
External corner tile mitres are not popular up here even if offered for no extra so metal trim is the most popular choice and easier/quicker to do and safer as it has a built in vice to hold trim
Do you change the blade to one without teeth or keep the one that is in the photo?
Do the trims snag at all?
GoneGuy,
demi34,
GoneGuy,
demi34,
