Discuss Tilers getting the blame for ufh burning out . in the General Off-topic Chat (nothing tile) area at TilersForums.com.
Ufh are very quick to blame the tiler for ufh wires burning out due to tenting when sticking down wires with tape but what about this.
you may have to enlarge it to see the gap . But my taping is always 100 percent better than that .
Uheat - Jake
TF Official Sponsor
743
The best way to stick a cable down if using loose wire is to tape it, before then coming along with a glue gun and gluing the cable firmly in place. Then remove the tape. From our experience not only can the tape create air gaps, but some adhesives won't stick to it either.
What is self levelling . I use a levelling compound but it doesn't do it on its own . I got to mix it , pour it , spread it , spike roller it . I even got to get it from the shop . There is nothing self about it .
And what about these companies that say you don't have level over the top just crack on with tiling, adhesive isn't going to run through there .
The best way if zc using loose cable is .ditra heat , vario pro , dural cifh etc ,
J Sid
had a job where the customer instead the electrician did the ufh install.
anyone spot the problems on this shower room floor? WP_20170918_08_00_39_Pro.jpg
I had a do off
Reply to Tilers getting the blame for ufh burning out . in the General Off-topic Chat (nothing tile) area at TilersForums.com
Tilers getting the blame for ufh burning out . > Tiling Advice - Tilers Forums
Uheat - Jake
TF Official Sponsor
743
J Sid
I had a do off
