Morning tilers, I did my back yesterday and it nearly put me on the deck, I’m in a bad way. Going to try and get booked in with the Physio today. Can barely move
Discuss Me, my back and I! in the General Off-topic Chat (nothing tile) area at TilersForums.com.
A Scotsman did that, and it hit him on the back of the head....!Just picking your wallet up after you’ve dropped it can be a nightmare
You manage to get in with a physio?Morning tilers, I did my back yesterday and it nearly put me on the deck, I’m in a bad way. Going to try and get booked in with the Physio today. Can barely move
You will going to Pilates then . Do they spandex in your size .Weak core muscles which in turn has caused me to pull some muscles in my lower back. Got some core muscle, lumbar stabilisation excercises to do and return in 3 weeks. Your lower spine has for example 6 movement points which all move the same amount when you bend your back, curved where as mine, one of them is more of a pivot point than the others because the muscles aren’t holding it all tight and that is probably why I’ve pulled back mucles. For the long term they need strengthening basically
Worse thing ever back pain Andy, did mine before christmas and Geoff @Plan Tec Tiling told me about a support belt..ActiveBak by clever yellow.com, should come up on google, wear mine every day and it really helps..Weak core muscles which in turn has caused me to pull some muscles in my lower back. Got some core muscle, lumbar stabilisation excercises to do and return in 3 weeks. Your lower spine has for example 6 movement points which all move the same amount when you bend your back, curved where as mine, one of them is more of a pivot point than the others because the muscles aren’t holding it all tight and that is probably why I’ve pulled back mucles. For the long term they need strengthening basically
Need to get deadlifting Andy, that’ll strengthen your core.Yes adey I’m about to go in in a moment, a private one.
Front of your thigh you mean?He’s started me off on these leg lift things, concentrating on the muscles that run down from just below the pelvis / hip bone
Reply to Me, my back and I! in the General Off-topic Chat (nothing tile) area at TilersForums.com
